Can anyone ID this style/ packaging material?
Postby CarlTiki » February 25th, 2014, 7:14 pm
CarlTiki
I am doing some research on packaging styles, and have happened upon a Package that would fit my client's project perfectly. Anyone know what type of plastic this is?
Imgur album here: http://imgur.com/a/kfcnE
Thanks!
SCAD '09
Re: Can anyone ID this style/ packaging material?
Postby Johnathan » February 26th, 2014, 12:43 am
Johnathan
Most of the time those types of bags are made from PVC.
Postby CarlTiki » February 26th, 2014, 6:15 pm
CarlTiki
I should be a bit more clear, I am looking for more information about how this particular style is manufactured.
I am assuming that they are PVC sheets, but are they pressed, heat welded, sonic welded, or something different?
Thanks!
SCAD '09
ralphzoontjens
I know that those ribbed seals can come from an ultrasonic welder - it has a ribbed wheel that is run along the perimeter of the packaging. Material looks like PVC.
If you don't see the ribs on the seal it's probably a heat bond - that's what they use for most plastic bags and ziploc bags.
I personally like ultrasonic welding - it's fast, uses less energy and may add to a professional appearance.
http://www.designsoul.nl
Return to branding, packaging, & retail design
