loganu
My design aims to solve bad-morning scenarios or rituals. A wall-mounted alarm clock/radio eliminates its owners ability to sleep in through the alarm.
The usual causes of sleeping in (through my personal experience only) are perpetual-snooze-button-slapping or alarm-unplugging, and phones losing battery power in the middle of the night and effectively disabling the alarm set on it.
loganu
The re-designed alarm clock does three things:
Makes you set an alarm
Makes you charge your electronics
And doesn't let you sleep until you've done both of them.
bed with lights.jpg (55.65 KiB) Viewed 3379 times
davo
step one
step one
I know, already taken...but still a great idea.
The difference here is not auto-on when pan is in place.
Many pans need to remain on the stove top and be off.
Travisimo
sort of gestural, sort of intrinsic reward system... the more you brush,
the brighter it glows, and over a day fades showing you brushed
under 1hr
designertyler
Proximity Sensing Headphones
When the user takes the ear bud out of their ear, the sensor will pause the music. When the user replaces the ear bud into the ear, the music continues. This helps the device better understand the user's intentions through their gestures.
Through better communication to the device, this streamlines the process of pausing music when the user is no longer listening to it.
anyone want to help me patent this? :D
Nerdspeed
step one
step one
Kind of surprised this hasn't come up yet.
You know you want it!
clam
step one
step one
Fed up having no job, cheered me up entering!
Re think of the answer phone system.
Problem: The pinncale of flat and boring devices are phones and their answere phones. Sitting\standing infront of a machine listening to messages with that air of uneeded anticipation of who left a message and then having to traipse through messages to get back to the one you wanted to listen to.
Solution: An answer phone system which stores messages in envolopes. open the envelope to hear your message (similar to birthday cards with recorded messages). Each envelope has a dry whipe surface so any details can be jotted down in addition the base displays the number who called and left the message, as well as a small led indicator to let you know there is a message in the envelope.
riegelman
Having had a number of experiences with roommates that who have the tendency to fall asleep in the shower, I humbly present a solution.
This shower head functions as the method to turn the shower on and off, a physical display of the amount of the time that you have been showering and a way of waking up those who might begin to doze in the comforting warmth of a good shower. If untouched, the shower head slowly descends and eventually shuts itself off - either prompting the user to wake up and start their day (again) or restart the shower to continue cleansing himself. For those without the tendency to fall asleep in the shower, this functions to remind the user of excessive water usage and waste.
cg
Standardized visual gesture library
drew1234
This idea is all about tracking time while designing. Our firm has used several software solutions to this problem (tick, timefox, ect.) but it would be nice to have a gestural interface as well (especially since I'm particularly bad at remembering to use them). Why not have pencils function like a stop-watch? I could have a pencil designated to each project- when I pick it up, the clock starts, when I put it to rest again, the clock stops.
rkuchinsky
designertyler wrote:Proximity Sensing Headphones
That already exists. Great minds think alike :) I can't recall who makes them, sony, maybe...saw it on Engadget or Gizmodo I think.
The Directive Collective
patrickandrews
This idea is a personalised movie interface embedded in a cup.
The base of the cup is made so that when the liquid has been drained to a certain degree (perhaps by using a moulded-in straw), the remaining pools in the base look like someone’s face.
Clever moulding of the base, before attaching it to a standard cylindrical wall element, could even result in the appearance of a sequence of different faces, or changes in expression of the original one, as it is drained. (This requires that the depressions in one mould overlap in area those of the next). Since the mould depth varies smoothly, this could be used to arrange a grey-level rendering of the face in question, via the varying darkness of the drink.
This would in effect provide the cup with a kind of internal film show interface mechanism without any electronics. Other subjects are possible, but faces lend themselves to easy recognition and also morphing from face to face.
A light shining upwards from underneath a transparent base could even be used to project the movie onto the ceiling.
A
gizmosaurus
The concept here is to allow operators of heavy machinery to coordinate the actions of their machines from a distance both safely and intuitively. The gestures from the remotes allow the user to move the arms, the tools and the position of the machines themselves. Pressing the button and aiming the remotes at a different machine will sync them to that machine, allowing a quick and easy change from task to task.
Holding the remotes next to each other and moving them in tandem could direct machines along a specific path wihle holding them apart and moving them separately would allow for precise control over their operations.
Hope you guys like it & nice job so far everyone!
mikewalker19
My design was done in roughly 30 minutes. Idea took a couple of moments in my head, second idea came as i worked in Illustrator. I came up with the relatively simple idea when being frustrated by long waits in queues at the bar! I really only drink one type of drink over and over if I'm socialising and so it can be frustrating having to wait in a long queue to do this.
My concept makes it easier to reorder a drink, without queuing. This would of course, need a waiting service to be available.
My first idea was to have coasters that either correspond to a certain type of drink or have the order info scanned into them, that the user would take to sit with their drink. The coaster would weigh the glass, and when the glass was full nothing would happen. When there was no glass on the coaster, nothing would happen. But when the user placed the glass on the coaster empty, this would order another of the same drink, to the table.
I then realised, giving customers a digital coaster can be annoying, like those coasters you get to let you know your dinner tbale is ready.
So idea 2:
A table with an integrated platform, or an additional mat or platform to place drinks on, that would be loacted in the middle of tables. The users can simply put their finished drink in this space to order the same again. The platform would have many 'weight spots' so that it can intelligently weigh more than one item at a time. Creating orders for several people at once.
I hope your love for beer (and hate for waiting times) means you have a love for this simple design too.
wireless id
Postby jlgrobe » May 30th, 2010, 1:24 am
jlgrobe
This is a wireless id, because it is permanently transmitting your ID and your status as a beacon, for your gadgets to get to know how far you are, and which your mood is. Your mood could make to be detected by sensors in the wristband that monitors your breathe, corporal heat, and heart beep. Or set manually.
Gadgets will know if you are near, and will execute a profile depending on the distance to your gadget. if friends are near, and they are using this beacon, your gadget can detect them.
More than optimizing energy consumption of every gadget connected, this interacts with your social networks, it manages the atmosphere of the room depending of your mood, and executes presets for behavior depending of who is with you, like playing the music you prefer for that moment, or dimerize the lights.
wireless id - julian grobe
