Re: 1HDC 10.02 - Emergency Shelter - Submission Forum
Postby theha » February 27th, 2010, 10:20 pm
theha
step one
step one
An Idea for emergency housing.
Hope it is of some interest
Peace
Max
Emergency Shelter Max
Julio Medrano
I propose a shelter with a PVC tubular structure, you know like a tent with a fresh and waterproof fabric. And a folding system, maybe it looks like a taco, but common im from México, the taco its our best folding system ever hahaha kidding.
Greetings.
Noob_IRL
My first 1HDC
Brief: Portable/stackable aid boxes can be flown in with helicopter. Frame made of aluminum plates with hinges, easily expands from the aid box. Tarp or fabric is provided inside to stretch over frame. When the tent is expanded, the aid box provides stability and collects water. Med kits, MREs, and other survival materials are provided inside aid box.
jkim6199
Compact Lightweight Recycled Plastic Shelter Unit.
This shelter is made of recycled plastic a feature is its practical and easy to use buttons which allows the shelter to be easily folded and reused. Recycled plastic makes costs lower and is quite durable and lightweight. In addition it contains a mesh to protect from insects and a water resistant film to protect from the hot weather and wet climate.
Jake Kim
Pop Up Shelter Design for Haiti Disaster.
david collett
Semi-Rigid Tent
I don't think that 'airdropped' emergency housing needs to be mutually exclusive with reconstructive development work. This emergency shelter can go up fast but also forms the basis for a customisable core dwelling.
The roof would be made of inflatable solar water heating panels or a woven vault like those proposed by Christopher Alexander.
My first one hour competition,
David Collett
enocarmengol
This a is a temporary inflatable tent contained inside of a jacket with a rear zip to open it. This inflatable tent can provide a temporary emergency shelter. The inflatable tent has an optimized common structure to give a light and semi-rigid tent.
It can be designed with variety of inflatable structures, like the one on the sketch.
Coccon emergencyshelter jacket
dbpuyo
step one
step one
77 Emergency Shelter.
I began thinking about proven "temporary" structures. We all use Tents, but I thought of TIPIs and thought how it would suit the given requirements.
Idea was to use Everything from the start and Reuse it in the future.
The unit consists of, the parachute, parachute cord, outer shell made with long "STEM" units, and inner units including: Light & Energy unit(fuel), Food unit, Medical unit, Water and filteration unit and Finally soft unit containing clothes and sleeping bags etc.
Once it is deployed, a user can open the bottom and release the inner units. Then the "Stem" units can be deployed and rooted and act like poles on TIPIs. The Parachutes are then used as the outer layer and fastened together with parachute chord into a TIPI structure.
The top "Light" unit can be used to send out different signals via colors and perhaps even pulsation to indicate current status of the occupants.
I don't have enough time to think about the materials for the STEMS or details on fabrication but this was an interesting hour. :mrgreen:
Bredderman
Introducing the Air Fortress
The Air Fortress is designed like an air mattress, but in a dome shape for shelter, the air mattress style design has an insulation effect in extreme weather conditions. It can be inflated by a battery operated pump common to air mattresses or by compressed air; we don't want disaster victims passing out from trying to manually inflate one of these, and it contains glue that hardens inside the walls upon inflation for a semi-permanent structure. It can be shipped with first-aid items and other necessities inside, as well as a reversible tarp or parachute (reflective/absorbing) for use depending on desire to collect solar energy.
jlgrobe
Caterpillar shelter
This shelter is made for being flexible to disaster´s city conditions. The only cleared path once the catastrophe has come are the streets, so this tube long is for passing trought the city ruins and debrids. Also it can sufer from earthquake replys, becouse its tensile and its anchored to a lot of surrounding buildings or ruins, so it doesnt need fundation. Becouse is a tube, its isolated from top and above. It can be ensambled be anyone becouse it doesnt have a "rigid shape".
Tube can be rolled and packed as a circus tent.
It also can be placed in squares anchored to trees, or among forests, adapting to ground and trees displacement.
First thing of a big scale disaster as ahiti is that it haves to be massive, flexible to conditions, and to be as almost near the city as it coulds. this is for what it was designed.
(in the graphic the shelter is placed in the street among building debrids and vehicles)
Caterpillar shelter
bak2_ID
I know this is very last minute but I really wanted to post this hoping it would generate some ideas for future catastrophes.
My idea is to use accessible construction materials to construct an emergency shelter.
In poor regions of Guatemala I have seen many homes constructed with these materials, which is what inspired me.
I made different sketches for the design but this one stood out because I thought it was more welcoming.
Thanks,
(Pictures from http://www.gettyimages.com)
kmonita
concept caterpillar
This design is a shelter system. The concept is based on the caterpillars structure, as this little insect , have several segments which help to fold and unfold quickly.
Is designed for being assemble for 2 persons, so it is a quick retreat to use and can protect people who use it. The shelter has a graphic on the top to be easily seen from the air if it is used in a natural disaster.
:D
NathanKing
SHIP ONLY WHAT IS NEEDED
1) each unit that is shipped is made of building material that can be reconfigured post disaster. It is inappropriate to ship a lot of items that will end up in the garbage. As people move out of this unit it can be disassembled and the material can be used in permanent construction.
2)all alike components are identical for easy rapid deployment.
3) fabric superstructure eliminates the need for watertight construction and provides passive cooling. This superstructure also allows for a second floor living space that is protected and off the ground.
4)foundation can be adapted from rubble, stones, etc and the unit is anchored using a helical foundation pier. These piers can also be used in final construction.
The rigid structure is roughly an 8' cube and all SIPS boards are US standard 4 x 8, 3.5 " thick and weigh under 20 lbs
kmonita
concept seed
Our proposal is inspired by the designs of nature, based on simple shapes to create a modular design. The design proposal has leds in the structures that are illuminated at night to be easily located by land or by air. As regards the materials, it has the innovative technology of a plastic material embedded with solar cells.
dylansnow
Inspired by Bee Colony's fast, flexible growth. Connectors allow for community to protect itself and sleep safely in a "I got your back" fashion while creating community spaces. Simplicity allows for ingenuity of the individual to modify unit to one's own need.
photo from http://www.flickr.com/photos/37913760@N03/4274634444
erynandkate
When a disaster occurs, it may take weeks in order to import portable, new, innovative, Western, structures. Instead of relying on plastic tarps or tents that are inappropriate for the extreme climate of Haiti or importing 'shelters' that look like they were built by aliens (especially to those in the 'developing world', we propose taking the materials available and building without increasing the carbon footprint. With the use of gabions (filled with rubble), scrap wood, and UN tents, this portable shelter is built BY the community and responds to cultural needs. It reassures safety and ventilation with easy access to materials, with the possibility of a long term shelter - (statistics show that 'emergency shelter' averages multiples years rather than months) - and the pride of a community that is important for survival of this Haitian culture that is so different than yours and mine.
