what is the best way to transfer my sketch underlay to the canson paper?
I allways ran it through a photocopier. You can also scan the sketch and run the canson through your printer.
Back in the day I would take a sheet of tracing paper and cover the whole sheet with Prismacolor Colored pencil, usually a light color that wasn’t used alot. Then I’d use it as transfer paper. I would save that tracing paper for a few years and even share it with the staff.
I used to do it that way myself. Then I found this stuff in the drafting section, kind of like carbon paper. Thin sheet, one side coated with yellow powder. Then you just trace your sketch through it onto the canson. Pretty cheap stuff. Not sure if it’s still around.
