Self Criticism
Postby jon_winebrenner » January 16th, 2013, 10:57 pm
jon_winebrenner
So, here I was tonight. Daughter barfing her guts out with the flu all last night, so she's watching TV. Son...if the TV's on, he can't do anything else but watch. Wife is out running. So I had an hour to myself. I cracked a bottle of red and just sat and drew. Whatever came to mind. Doodled.
So, the question is.....how do you all tackle the issue of self-criticism?
I can draw. I'm no Michealangelo. But I can communicate with a drawing utensil.
My problem, is when I'm drawing...I'm my worst critic. So, a drawing session can go one of two ways. It can start off well, and it just gets better b/c it is working. The flow is good, line weight seems to click, etc.
Then there's the other times. Nothing works. It starts out bad, and it just gets worse. I tighten up. Everything is forced.
It is the latter that I wonder about. I know I'm not alone. But how do you handle it?
Re: Self Criticism
Postby apowers » January 16th, 2013, 11:12 pm
apowers
I asked an instructor of mine what he does on his "bad" days of sketching because I was stuck in a rut. He said he just does something else, like 3d modelling. However, some of my best sketches have come right after I say to myself "Man, I'm really sucking right now" and spend a good chunk of time on a random, loose sketch that I'm not really paying attention to which comes out pretty decent. I don't really have a solution since I try to work through it to get the weeks assignment done, but good luck!
Aaron Powers
Footwear Designer at Nike
Academy of Art University Graduate - 2016
My design school journey: viewtopic.php?f=27&t=28022
My Behance: https://www.behance.net/Apowers
IG: Sketchpowers
Re: Self Criticism
Postby ADD » January 16th, 2013, 11:53 pm
ADD
I think that's the time to do the practice drawing... Straight lines, Spirals, Circles.
Use the energy... :idea:
Re: Self Criticism
Postby Almo50 » January 17th, 2013, 6:43 am
Almo50
jon_winebrenner wrote:It can start off well, and it just gets better b/c it is working. The flow is good, line weight seems to click, etc.
I'm not sure what word to use, i'll use low peak and high peak. My high peak, when my mind is most active is towards the late evening even past midnight when I'm really on the ball.
Re: Self Criticism
Postby Dov144 » January 17th, 2013, 9:24 am
Dov144
I know for me I am the same way, as far as being my own worst critique when my drawings/ sketching are not flowing the way I want I just try to power through and hope I get a few good ideas to revisit later. In the end it is just a sketch... Lately though I have been taking speed painting breaks and doing landscapes or figures and it has really loosened me up and been a nice break.
Re: Self Criticism
Postby jon_winebrenner » January 17th, 2013, 9:51 am
jon_winebrenner
Ya, everyone has cycles like this, apparently. I'm on my iPhone so I'm not going to go digging up articles....but it's along the lines of circadian rhythms.
My groove tends to be between 11AM until it fades. Some days that 11:02, others its into the wee hours.
Re: Self Criticism
Postby Brett_nyc » January 17th, 2013, 10:24 am
Brett_nyc
When I'm laying down junk, I mentally switch into "recorder" mode where I'm putting down just enough chicken scratch to remember later what I was thinking, or the train of thought.
Re: Self Criticism
Postby engelhjs » January 17th, 2013, 1:23 pm
engelhjs
One of the best workflow/mindset pieces of wisdom I've heard came from a friend of mine who was working as an animator at the time. They were under a ridiculous time crunch, and were pumping out animations and renderings around the clock. He said that, because there were so many characters, shots, scenes and environments to be done, he realized that every one can't be his masterpiece. It wasn't succumbing to failure. It was understanding that in his lifetime he'll do so many animations there are bound to be a few clunkers in there.
Recognize you're unhappy with your work, understand that bad sketches are bound to happen, move on and don't dwell.
Jeff Engelhardt
Industrial Designer - Footwear & Softgoods
Giro Sport Design
Santa Cruz, CA
http://www.jeff-engelhardt.com
Re: Self Criticism
Postby Travisimo » January 17th, 2013, 1:51 pm
Travisimo
Brett_nyc wrote:When I'm laying down junk, I mentally switch into "recorder" mode where I'm putting down just enough chicken scratch to remember later what I was thinking, or the train of thought.
engelhjs wrote:understand that bad sketches are bound to happen, move on and don't dwell.
I like that way of thinking.
it's easy to get caught up in making the perfect sketch, when the end goal is usually a physical product and generating good ideas for it
Re: Self Criticism
Postby IDAL » January 17th, 2013, 2:19 pm
IDAL
That's what exactly happens to me. You can't always be on your high peak but you can use your low ones to do none challenging duties or just do something completely different to clean your mind. For me listening to new music, do some cleaning, take a shower, etc, works pretty well. Usually, after that I'm ready again.
Alejandro Lara
____________
Observe
Explore
Create
Re: Self Criticism
Postby yo » January 18th, 2013, 11:21 pm
I usually switch mediums. It always helps to jog me out of a rut.
The worst is when I spend a lot of time on a sketch, sometimes I know it is wrong, but I just keep investing time thinking I can fix it. Then I step back from it and realize it sucks and punish myself for wasting an hour on garbage.
My best sketches tend to be when I'm thinking about something else entirely, and it is just a quick little flow, effortless. It can be hard to get into the state of mind. Music helps of course, as does the setting, I almost never ever sketch at my desk. At my first job we all sketched at a conference table in the middle of the studio and I got accustomed to that. It feels more causal.
My favorite time to sketch is early. I'm usually the first one in the studio and sometimes when I get in, before I even take my laptop out of my bag, I'll put some music on loud (we have a lot of audio equipment) and pound out a sketch or two.
Re: Self Criticism
Postby mixel » January 19th, 2013, 9:26 am
mixel
Interesting topic to read about.
Most time when I tighten up is because I try too much and force myself to keep on sketching. The first thing I try is to scribble a bit on a new paper, it is a bit like the practice drawing. When that doesn't help I put my mind on something else by doing something else as IDAL mentioned.
Sometimes I try to get inspired by the work of others on websites and in books. This can also work negative for me as I do think all my doodles don't look good in comparison to the work I have seen.
Finally I just quit and start working on it another day :)
yo wrote:I usually switch mediums. It always helps to jog me out of a rut.
By switching mediums do you mean from paper to digital or more from a pencil to a felt-tip pen?
Re: Self Criticism
Postby yo » January 19th, 2013, 5:37 pm
Both. Sometimes I'll switch from a super soft prisma color pencil, to ball point, or felt tip, or sharpie, or go digital, but usually I stay analog.
Re: Self Criticism
Postby mo-i » January 20th, 2013, 10:25 am
mo-i
Good to hear, that even amongst the best professionals a bad sketch is not unheard
off. When I was younger I had no problem staying in the flow as sketching was my
way to procastrinate the maths homework.
When I did sketch for a living things got a little more complicated. The internet didn't
help. Looking at others peoples work might inspire, but not when "in a rut". Switching
the pencil does the trick. Thanks for reminding me of that.
mo-i
I am not young enough to know everything.
Oscar Wilde
Re: Self Criticism
Postby jon_winebrenner » January 22nd, 2013, 11:50 am
jon_winebrenner
I agree, Mo-i....this is a huge part of why I love the boards. They remind you that everyone on here is human and has the same speed bumps along their career.
I still remember when I was working with Yo and a couple others here on the board on The Brief DVD....I loved watching the other designers work. The main thing that I always caught when watching others sketch is their speed. It is WAY slower than I imagine it "should" be done. There's so much empahsis on "cranking out ideas" that I think quality tends to get wrapped up in that equation.
Watch some of the videos here on the boards of guys like Blaster....he is methodical in his approach. Slow and sure wins the race....as they say.
Go to the Next Page
Return to sketching
