Boot render
Postby jtindi » October 29th, 2014, 8:14 pm
jtindi
Hello my name is Jeffrey, I'm currently a junior ID student at SCAD. I'll be posting a lot of my sketches/renders to get feed back and to make connections with industry professionals. First post! thanks
Hi res image: https://www.behance.net/gallery/2061625 ... -(Personal)
Re: Boot render
Postby rkuchinsky » October 29th, 2014, 9:09 pm
rkuchinsky
Welcome. Check your proportions. Toe looks really long. Should be about half that.
The Directive Collective
Re: Boot render
Postby chevisw » October 30th, 2014, 8:01 am
chevisw
you over all rendering needs a little work.
1. better define the form with high lights - lightest lites against darkest darks
2. give some dept to the stitching - using the deboss tool is PS is a qucik simple way or if you are using sketch book pro create a custom brush
3. draw in form lines on a separate layer to help you visualize where you want your highlights and shadow
use reference material, here is a quick one i found that will help steer you in a direction
also don't just have ref. samples of other people renderings in front of you have images or actual samples of the materials in front of you as well. Study and duplicate what you see.
Re: Boot render
Postby yo » October 30th, 2014, 11:58 am
That Puma sketch is pretty hot, who did that Chevis?
Re: Boot render
Postby jtindi » October 30th, 2014, 11:02 pm
jtindi
thanks everyone!
Re: Boot render
Postby chevisw » October 31st, 2014, 8:59 am
chevisw
Not sure who did it YO, it was a random web search. But i agree very nice.
Re: Boot render
Postby bngi » October 31st, 2014, 10:13 am
bngi
yo wrote:That Puma sketch is pretty hot, who did that Chevis?
Tom Weightman (http://www.coroflot.com/tomweightman/puma-personal-work)
Björn Bengtsson
iddqdse
"the unicorns do not look realistic enough"
Re: Boot render
Postby chevisw » October 31st, 2014, 1:25 pm
chevisw
Sure glad i didnt respond to YO with " what that thing i threw down some quick lines to use as a ref for this conversation" ;)
reminds me of a time a designer responded with "you never asked if they where my designs you just asked if they where my sketches"
Return to footwear & softgoods
