I need to purchase a Strobel machine for a project . The machine should be able to attach a insole to a liner which will in turn fit into another outer “shell”. Anyone know of where I can see and purchase one of these machines?
cantman@speakeasy.net
is it for manufacture or just protoyping.
if its for protoyping you can hand stitch it with a triple running stitch in a triangular pattern–'cause all a strobel stitcher does is stitch the triple running stitch at a 90 degree angle with a heavy weight thread at high speed/pressure.
are you using a die cut insole to attach to a woven/non woven lining material?
how will the insole/lining be attched to the outer shell?
just asking…
Thanks for the quick reply!
- Manufacture
- Die cut insole stitched to non woven insulating material
- Liner will not be attached to the outer shell (Ski Boot)
I make custom ski boots and I need the Strobel stitcher to manufacture the liners.
Thanks.
Will Kaplan
Performance Pedorthics
try these guys:
http://www.pilgrimshoemachine.com
they have rebuilt machines. Their might be expensive. But at least they are in the US and can probably get you what you want
good luck[/url]
Thanks!
They were already on my list!
Will
