Re: Sketch-Fu: Men's Footwear
Postby Kershaw » December 4th, 2017, 8:05 pm
Kershaw
rkuchinsky wrote:A fun quickie sketch collab using a midsole/outsole kindly provided by user plinus ...
Love it!!
Postby rkuchinsky » December 5th, 2017, 9:13 am
rkuchinsky
Thanks Kershaw... Trying to sketch more for fun...
Here's a new morning doodle.
XC Spike.
The Directive Collective
Postby junglebrodda » December 9th, 2017, 6:45 am
junglebrodda
a not so quick quickie
no ideas original....there is nothing new under the sun...it is never what you do but how it is done
https://www.behance.net/a0o
Postby yo » December 9th, 2017, 10:03 am
When I see them done in illustrator like this my eye is so much more critical of the proportions.
Postby junglebrodda » December 9th, 2017, 1:37 pm
junglebrodda
sure, all the little inconsistencies stand out in a way you'd be less likely to care/notice/see in a loose(r) sketch because one can be so precise w/illustrator
Postby yo » December 10th, 2017, 1:51 pm
In some ways actually just the opposite, it is shellack of variation that makes it feel less real if that makes sense?
For example:
would those flex outs to a stretch material along the top of the forefoot really be straight lines, or would they arc subtly to follow the form of the foot? Would they be at the exact same angle, or would they fan slightly? Would the ends be full rads or would they have a bias? They also don't seem to talk at all to the triangulated toe cap.
I think these things are rather easy to address in a sketch, but a bit harder to see in a vector program where being efficient with the tool means using some of the stock features. And that is just the details... really the proportion needs to be addressed first.
Some of these things are a bit more forgivable as a pencil sketch (analog or digital) where the focus can be on the core idea.
That said, I did see a few things that I'll bring into my illustrator work flow :D
Postby junglebrodda » December 10th, 2017, 7:58 pm
junglebrodda
i think we're saying similar tings, hand sketches typically get a little more leeway and i've 'illustratored' it in such a way that the expectation is that it should be more resolved...had i done a sketch of this 1st i might have come to a more resolved solution(s), admittedly these are light on amount of thought and would benefit from more consideration so i see what you mean with the general mish-mash of elements...curious where and to what extent the proportions are off though?
Postby yo » December 11th, 2017, 9:35 am
I’ll work up a quick proportion study today. Are you thinking it is a basketball shoe or more fashion based? If fashion then it can be more exaggerated like this (though the throat opening is still really small for a laceless shoe).
Postby rkuchinsky » December 11th, 2017, 9:55 am
rkuchinsky
yo wrote:I’ll work up a quick proportion study today. Are you thinking it is a basketball shoe or more fashion based? If fashion then it can be more exaggerated like this (though the throat opening is still really small for a laceless shoe).
I think everyone has their own eye for proportions... Some like to exaggerate the toe length, toespingm or have more narrow collar or higher collar line. Truth be told, unless very off, I think it's a matter of preference.
When teaching footwear design, I always pushed accurate(ish) proportion, but also showed a series of sketch overlays of from a variety of designers including my own, Michael's, and a bunch of other footwear pros just to show that there is also some variety and variation...
I'd agree the other details for the sake of speed on the Illustrator art are more an issue and fit with the finished look of the render.
Postby junglebrodda » December 11th, 2017, 11:38 am
junglebrodda
neither, was vaguely thinking of a way to make a deconstructed run-able trainer, more supportive but i fell into more conventional hoops look...for the throat, i was going for that sock feel, those shoes can look impossible to get into if not for the ample stretchiness, and even still are tricky for some to put on (so: zipper!)
seeing the overall stiffness is the thing that i've noticed the most from doing these...some of that is due to the way i've been doing them, but moreso the level of thought doesn't necessarily match up to the execution
Postby yo » December 11th, 2017, 1:28 pm
Great discussion here. One of the things I learned (the hard way) is that the level of execution has to balance out the level of thought. A part of the the talk I gave at square one was in the different levels of visual communication and what was appropriate for where you are in the process.
The three levels I identify are:
1) exploration (conversation with yourself or peers)
2) communication (multi person conversation outside of the core group)
3) persuasion (definition and alignment)
And the continuum I place those on are from "What it can be" to "What it will be"
Of course there are an infinite way to articulate and identify these things, but for the sake of a simple framework, go with me here. Your technique level is somewhere between "Communication" and "Persuasion" but your intent level is "What it could be" so the result is cognitive dissonance and people nit picking on stuff where you just want to be like "come on dude, its a sketch!"
any of this make sense or helpful in any way?
Postby rkuchinsky » December 11th, 2017, 1:31 pm
rkuchinsky
Postby yo » December 11th, 2017, 1:48 pm
and to answer you proportional question, I think for the kind of shoe you described the Nike Air Moire Mid (which proving impossible to find images of, ugh, it was an early 200's shoe and the first to have nike plus, designed by Mark Smith, I loved that shoe. Shot of the low top attached) would be a good reference, or even the Jordan T4G that I worked on, though that was a bit more hoops inspired. It was built on a running shoe last though.
Anyway, I did a little liquify on your sketch so you can see what I'm talking about. When I worked for D'Wayne Edwards in Jordan he wouldn't even look at a sketch at this level if it wasn't close enough to the right proportion, so he might have overly trained me to be a stickler here. :-)
I know it is a lot less sexy, and you can cheat it a little more than I did, but I wanted to show the other extreme. The nike x Acronym Presto is another good reference (deconstructed stuff aside)
Screen Shot 2017-12-11 at 10.40.10 AM.jpg (139.97 KiB) Viewed 1166 times
Screen Shot 2017-12-11 at 10.40.20 AM.jpg (141.09 KiB) Viewed 1166 times
Postby rkuchinsky » December 11th, 2017, 1:54 pm
rkuchinsky
Collar can be pretty tight tho.
For additional reference.
Great discussion!
Postby yo » December 11th, 2017, 1:59 pm
totally, if it is a knit construction like those examples. The sketch doesn't show that though... which is why it is so wide in the Acronym Presto.
Side note, Richard, what do you think of those Balenciagas? I didn't like them in pictures but then I saw someone wearing a pair and I'm chasing my mind a bit.
Return to footwear & softgoods
