Re: Sketch-Fu: Men's Footwear
Postby ppadilla » January 27th, 2013, 12:39 pm
ppadilla
djones11 wrote:Hi everyone,
Just finished a render of a Nike Huarache Lacrosse Turf shoe based on an image I downloaded. Thought I'd emulate a real photo of a product to try to make my visual as realistic as possible, learned quite a lot from this. Any tips/advice? I feel like I could definitely communicate the laces better in terms of texture and shading. Find detailed areas of shading difficult to construct using the brush tool sometimes.
Look forward to hearing some constructive comments!
D
PS: find more of my visuals at http://djones3291.tumblr.com
Hi djones
Good work. You seem to have a pretty solid grasp on rendering skills. I would recommend finding a good lateral view template instead of a photo, because photos sometimes appear skewed and can make it tricky to communicate your sketch. For instance, the photo you used looks to be angled slightly past a straight lateral view, but not enough to make it a true 3/4 view. You have a very strong start, take it to the next level and apply it to an original design.
Postby ppadilla » January 27th, 2013, 8:04 pm
ppadilla
Sunday boot sketch.
Postby alexb92 » January 27th, 2013, 8:35 pm
alexb92
phil - I'm loving the boot pull strap! it really adds character to the boot and helps pull your eye from detailed lacing area and outsole. love it!
Postby damonski » January 27th, 2013, 9:44 pm
damonski
Hi all, just found this board and discussion and think it is really great!
Postby ADD » January 27th, 2013, 11:47 pm
ADD
Nice render & Interesting toe box design there, Damonski.
Postby designer23 » January 28th, 2013, 4:26 pm
designer23
Been a while... here are a few quick sketches. All comments welcome.
Postby damonski » January 28th, 2013, 11:06 pm
damonski
Thanks ADD...Nice work on your portfolio link site...
Postby Dov144 » January 29th, 2013, 12:38 am
Dov144
First time trying to render a shoe, this is a work in progress, design is nothing crazy new mostly focusing on the form reading and practicing working between illustrator and PS.
Update: This is close to the finale as this is due tomorrow for class I will keep tweaking it a bit, I really need to loosen up my renderings I will probably do some speed paintings of shoes and see what comes from that. Any feedback is much appreciated
Postby ScoRo5 » January 30th, 2013, 12:32 pm
ScoRo5
Another one of my quick modo styling studies.
Postby viperoshanali » January 30th, 2013, 5:37 pm
viperoshanali
@Padilla Great sketch over there! Liking the orthographic sketch of the pull tab to the left. Very inspiring I must add.
Postby ppadilla » January 31st, 2013, 3:26 am
ppadilla
Thanks Viper and Alex. Nice sketch page Viper, diggin' the simple clean designs you've got there.
Mid-week skate shoe sketch...
Postby Dov144 » January 31st, 2013, 11:41 pm
Dov144
Warm up speed paint sketch
Postby nordmade » February 1st, 2013, 7:08 am
nordmade
ScoRo5 - Your sketches are very unique however from a styling point of view there are so many panels [i'm assuming they're components] shapes, colour flashes all fighting for position, and i'm not sure if this is working. Generally with conventional footwear styling there are certain ways components are shaped too accentuate the curvaceaous lines on the vamp or to mirror the eyelet/facing panels. I think if you were to start and consider more conventional footwear patterns as a basis, and then work in your own styling elements then you may see more progression. The textures are also a bit puzzling as they're making the shoe look more like paper mache.
good luck
Postby Jason Mac » February 1st, 2013, 2:41 pm
Jason Mac
Wassup fellow sneakerheads! First time posting so any advice would be much obliged!
Postby Jason Mac » February 1st, 2013, 2:44 pm
Jason Mac
Just another marker render that holds similar qualities
Return to footwear & softgoods
