How to mount this spherical bookshelf?
Postby harryhutton » September 28th, 2014, 7:38 am
harryhutton
Hey guys,
How would you go about mounting this to a wall? - whilst keeping mounting panels discreet
Re: How to mount this spherical bookshelf?
Postby edvin_m » September 28th, 2014, 9:13 am
edvin_m
Steel bracket that then attaches to the bookshelf with some kind of hook hidden inside two of the vertical parts?
Postby Scott Bennett » September 28th, 2014, 12:03 pm
Scott Bennett
Keyhole fasteners?
Postby Dubya » September 28th, 2014, 5:12 pm
Dubya
step two
step two
How big is the shelf? Without anything showing scale its hard to say what would work.
Postby Azrehan » September 28th, 2014, 7:23 pm
Azrehan
1) Draw pencil lines with a straight edge where your verticals are going to sit.
2) Mark the points where the intersections between the verticals and horizontals will be located.
3) Drill and insert wall plugs into the wall at the points where the intersections are.
4) Drill and countersink holes through the verticals at the same point. and attach them to the wall using a counter sunk screw and long driver extension or very long screwdriver.
5) Push the horizontals onto the verticals. If your tolerance is right, you shouldn't need any adhesive, but if you do, be careful what you use because of runoff. Also if your glue is too strong, you'll need to break the unit to remove it.
Also, come to think of it, you may want to drill your holes first, have someone assist you, and mark the wall with a pen/pencil through the holes to make it more accurate.
Postby rukka » September 29th, 2014, 7:21 am
rukka
step two
step two
http://www.ikea.com/gb/en/assembly_instructions/lack-wall-shelf__AA-200208-9_pub.pdf
Although I when I bought a set at Uni (a fair few years ago) I'm sure there was a bracket you fixed to the wall with two protruding lengths of tube that aligned with blind holes in the shelf itself.
Edit. aka like this:
http://www.ikea.com/gb/en/assembly_instructions/lack-wall-shelf__AA-24442-7_pub.pdf
Postby Dan Lewis » September 29th, 2014, 1:32 pm
Dan Lewis
Postby Traftos » September 29th, 2014, 1:47 pm
Traftos
step two
step two
Like others said, Keyhole fittings to go into the back of the shelving unit.
But also, the wall anchor is going to be important as well. I would use a heavy duty wall 'Toggler" or a self drilling wall anchor. They can hold a lot of weight and wont blow out of the wall.
Return to furniture
