Re: Design Critique
Postby yo » June 21st, 2017, 2:42 pm
You need to show how people interact with it then think. I understand how a wearable is worn, show me how I use it.
Re: Design Critique
Postby tommyle » June 21st, 2017, 3:07 pm
tommyle
step two
step two
yo wrote:You need to show how people interact with it then think. I understand how a wearable is worn, show me how I use it.
Yo, besides speaking to it for commands or questions (which I think I've shown effectively right?), are you referring to interacting with it for other things like turning it on/off, changing volume? (In which I think I'd feature a touch capacitive surface)
Re: Design Critique
Postby yo » June 21st, 2017, 3:45 pm
Sorry, I totally missed that update to those images! That helps. It is pretty easy to miss those call outs though. I'd probably make it a notch more obvious... without making them look like comic book bubbles. What you did really helps though.
Re: Design Critique
Postby ralphzoontjens » June 22nd, 2017, 5:13 am
ralphzoontjens
Hi Tommy,
I like the project and I think there is a great need to explore what a smartwatch can be!
You have some good ideas and made good steps towards an implementable design. Your renders are decent and the sketches are clear.
Work more with textures and get the sharpness right to get a realistic look. See if you can add more character to the visualizations.
A few initial remarks are the scatter texture - this happened to my Samsung Gear too after I forgot to remove it in the spray painting area and was working with chrome. It doesn't really add interest to this product in my view. I like that you chose a round design, this is this thing I have with watches needing to be round, it's just the only shape that works.
For a project of this scope you can go much further into conceptualizing what the smartwatch can be. You need to map out all use cases and explore possible interactions to come up with a scenario that works. Removing a touchscreen is a bold idea but what you are really talking about is removing screen-based interaction. You can still use the screen or use touch interaction. I prefer mechanical touch input like wheels and knobs, and can see the value of voice feedback. I see a watch display mostly fit to give one type of information at a quick glance, it is a peripheral device to me.
I agree a touchscreen input is not optimal - you get fingerprints and no haptic feedback, you have to carefully look where you are pressing. So a simple button in the center makes sense. You can think about navigation styles with simple mechanical feedback or beep-like sounds with different frequencies giving feedback of where you are in the navigational structure, then you can lay your finger on top of the button (hovering is also possible with capsens) and get voice-feedback, then pressing will get you further into the menus. If you keep a simple interaction style and reflect it in the product design like you are doing, you can create a very successful concept. Keep exploring and integrating different ideas while keeping a clear view of where you want the design to go.
Also don't underestimate annular snap fit systems - you need to show some calculations before you can prove it is a workable and durable solution.
CNCed aluminum is probably a good idea for this + with an anodized finish it will look great.
http://www.designsoul.nl
Re: Design Critique
Postby tommyle » June 22nd, 2017, 1:33 pm
tommyle
step two
step two
ralphzoontjens wrote:Hi Tommy,
Really in depth and high level feedback, thank you! I'll explore more types of interactions like you said. But not sure why you'd need physical interactions beyond the basics..? volume, on/off, home, sync Bluetooth, shuffling music. Other than that everything could be voice right?
For use cases I'm specifically targeting features for on-the-go scenarios: activity tracking, GPS, ID card, NFC payment, RFID tag, keyless security, and connecting to bluetooth earbuds.. what about calls/messaging, should that be left to your phone?
Re: Design Critique
Postby AFonder » June 27th, 2017, 10:39 am
AFonder
Hi Tommy, this is Allison from Core77- Just noticed you're trying to get feedback on your project and wanted to add that we also have a Facebook group we just started for the very purpose of getting feedback from fellow designers if you're looking for more resources! https://www.facebook.com/groups/1747835 ... 9617883479
Re: Design Critique
Postby tommyle » June 27th, 2017, 9:58 pm
tommyle
step two
step two
Thank you for the extra resource!
Previous
Return to projects
