jon_winebrenner
You know, I'm embarrassed to say this...but in 23 years of designing plastic products, I've never had to put on a drawing a definition of a polish level. I've always just handed a sample to the toolmaker and said replicate this, or gave it a subjective definition of "high polish" or "mirror finish".
So, I have no clue what SPI definitions relate to a surface finish of something like a Lego Brick.
Google hasn't come up, quickly, with a layman's example of polish definitions.
Anyone help me out here?
Re: What Polish Definition is a Lego Brick?
Postby FH13 » May 17th, 2017, 5:41 pm
FH13
Hope this helps.
http://www.professional-plastic-mold-ma ... -approach/
Without looking at samples, Legos I would imagine are (just guessing):
SPI Finish A3 – 718H or S136 Hardness 32HRC
(Generally called “Normal Glossy” in China)
Good luck.
Postby FH13 » May 17th, 2017, 5:51 pm
FH13
Have you also tried a Mold-Tech catalog? Usually they have texture finishes, i assume they would also have polish finishes.
jon_winebrenner
That is one of the links I found when Googling about. It gives quantitative descriptions based on grit and materials used, but there is no real world comparison.
Ironically, from the descriptions, I was assuming SPI A3 was what was used for Lego blocks as well.
Brian_Donlin
FH13 wrote:Have you also tried a Mold-Tech catalog? Usually they have texture finishes, i assume they would also have polish finishes.
The mold-tech catalog I use does not have different glossy finishes. It's more for textures and varying degrees of matte. Not sure if there's a bigger MT catalog available, though. I think the one we had was like $400-500.
ralphzoontjens
This is a concurrent thread: viewtopic.php?f=2&t=8134
http://www.designsoul.nl
Postby iab » May 18th, 2017, 7:47 am
iab
For a clear polycarbonate "window", I used SPI-A2.
Then there is this handy chart,
http://www.balesusa.com/finishes/
Cyberdemon
Probably A3, usually when doing high polish you only go higher when it is a part with optical properties.
A3 finishes are more usually resistant to scratches as well compared to an A1. A1 parts are so smooth that even the slightest abrasion during handling or use will quickly scuff the surface of your plastic.
jon_winebrenner
Awesome...thanks, guys!
jon_winebrenner
ralphzoontjens wrote:This is a concurrent thread: viewtopic.php?f=2&t=8134
Moldtech is definitely not gloss and SPI surface definition. MT and Yick Sang are chemical etching process providing consistent surface textures.
