Plastic decoration methods
Postby idchick » January 18th, 2016, 9:34 pm
idchick
I need some help figuring out what's the best method to achieve this look:
Reference image
It's a cylindrical piece and ideally soft-touch with the pattern being gloss. The pattern could be thicker and have some depth to it. Any ideas?
Re: Plastic decoration methods
Postby Cyberdemon » January 18th, 2016, 10:13 pm
Cyberdemon
Probably a bunch of different ways, depending on the pattern could just be a gloss base part that gets masked and then has the soft touch paint applied. Mask removed, glossy areas remain.
If you wanted it in the raw plastic, it could be molded into the tool with a matte surface at one level, and then the recess can be polished to create the contrasting look. There would need to be a small step in the plastic as well.
You can also paint the part gloss black, then soft touch on top, and then do laser etching to remove the paint and expose the base part, or a secondary paint layer.
Postby Dan Lewis » January 19th, 2016, 9:30 am
Dan Lewis
What's the diameter and height -- may be possible to silk screen the gloss pattern on the soft touch surface. I've seen cylindrical printers up to about 18" dia. Maybe there are larger.
Postby idchick » January 22nd, 2016, 4:33 pm
idchick
Thanks for the responses!
It's a pretty small piece, the diameter is 4" and height is 2"
Postby ralphzoontjens » March 15th, 2016, 5:19 am
ralphzoontjens
Laser etching seems to be the way to go. There are rotary attachments for laser cutters as well so you can engrave cylindrical objects.
Alternatively, consider hydrographic printing/dipping which can be used on any 3d geometry
http://makezine.com/2014/02/25/add-patt ... phic-film/
http://www.id-z.one
