DMLS service recommendations
Postby iab » October 6th, 2015, 9:48 am
iab
Looking for a direct metal laser sintering house. I would like to make some stainless bicycle lugs. Basically 2 38mm tubes with a 1.2mm wall conjoined.
I've done the random Google thing. How about a recommendation instead?
Re: DMLS service recommendations
Postby FH13 » October 6th, 2015, 12:22 pm
FH13
I did some quoting a while back. Crazy expensive. Is machining them out of the question?
Postby FH13 » October 6th, 2015, 12:34 pm
FH13
I got quotes from Quickparts and ProtoLabs (Fineline Additive Manufacturing). The bigger companies are acquiring the smaller guys + I have a feeling they might also be outsourcing some of their jobs to prototype houses in Asia as well.
Best bet is to get 3 quotes and talk to them about the material and finish since it will make a difference.
At the end we ended up getting the parts we needed machined in SS from a prototype house in China, but it would take about 2 weeks lead time.
Postby iab » October 6th, 2015, 12:56 pm
iab
I have an rfq from Star out of China. I've used them before. Fineline threw me a crazy high number then I tried a random place and they were 1/3 the price of Fineline. I'd like to stay away from random picks but this is a new process to me.
As for machining, I have gotten 3 no ways so far. Complicated 6-axis stuff with a think wall. I imagine making the fixtures to hold the stuff could be a problem.
I am also looking into a rapid investment cast. Print the parts out of wax, etc.
Here are some screen grabs of the models.
ImageLugs09 by iabisdb, on Flickr
ImageLugs11 by iabisdb, on Flickr
Postby FH13 » October 6th, 2015, 1:36 pm
FH13
Same here. I was very hesitant to use DMLS because of high cost, prices varied so much, and tight tolerances were a must... and all 3 bureaus had different orientation & finishing options.
We have used RP prototype in China.
http://www.rpprototype.com/
Emelda Cariaga - emelda@rpprototype.com
You can contact them and see what they say.
Postby KenoLeon » October 6th, 2015, 2:12 pm
KenoLeon
Just curious, would something like Shapeways steel not be up to your tolerances,price range...
http://www.shapeways.com/materials/steel?li=nav
Eugenio (Keno) Leon
k3no.com Linkedin Instagram
Postby Dan Lewis » October 6th, 2015, 4:00 pm
Dan Lewis
Investment cast stainless will give you a better finish.
Postby iab » October 6th, 2015, 4:08 pm
iab
Shapeways "steel" is 40% bronze and melts at 1600F. Stainless anneals at 1900F and melts at 2800F.
While an interesting material, I need the strength of stainless.
Postby iab » October 6th, 2015, 4:09 pm
iab
Dan Lewis wrote:Investment cast stainless will give you a better finish.
Probably less sanding and polishing time with IC. But I'm time rich, cash poor. Easy math for me.
Postby Sain » October 6th, 2015, 4:47 pm
Sain
You can prob can find someone with a Formlabs and casting resin to get you a quote. Will be cheaper than Shapeways. etc.
Ex. https://www.3dhubs.com/calgary/hubs/gary
emmanuel carrillo - emmanuelcarrillo.com
Postby Dan Lewis » October 7th, 2015, 8:27 am
Dan Lewis
I think direct investment casting from a wax RP will be less costly than DMLS.
Postby iab » October 7th, 2015, 11:12 am
iab
Dan Lewis wrote:I think direct investment casting from a wax RP will be less costly than DMLS.
I think you are right, but it is too early to call at this time. Not a lot of places like making a one-off, rapid IC or DMLS. I have a lot of rfqs out there but not a lot of replies.
I need to start to call with a follow-up. You get a better response.
Postby iab » October 7th, 2015, 11:13 am
iab
FH13 wrote:You can contact them and see what they say.
Can't hurt. Thanks for the lead!
