Hi Core,
I wanted to experiment with casting electronics into silicone or possibly urethane.
I was hoping to be able to cast the parts in different degrees of ‘stretchiness’.
Does the shore hardness give a good indication of how stretchy the cast silicone will be?
Also I noticed that the silicone mold-making/casting products came with additives to increase or decrease the viscosity of the silicone while pouring. Could these possibly be used to make the final part more/less stretchy
I suppose I could use any flexible casting product. I called the local tap plastics to ask but their response was “Silicone is not a casting product… you can’t do that…” I was fairly certain you could, aside from casting platinum based silicone in a tin based mold.
Could anyone shed any light on the subject for me?
Thanks so much for your help!
