Material for inflatable toy system
Postby amanda » October 24th, 2004, 11:35 pm
amanda
Hello-
I am currently working on a project and I need any information on PVC sheet or Vinyl sheet suppliers. I am making a product out of the material pool floats are made from. I have found some manufacturers but they have a large minimum order. I am looking for an assortment of colors and thickness ranging from .008-.020.
Please help- Thanks :roll:
Postby dmuren » October 25th, 2004, 12:58 am
dmuren
step two
step two
I've had similar problems finding colored vinly. You can buy clear vinyl sheet at most fabric stores (but it's probably .015''-.020'' at the thinnest). As far as coloring it, you might try Krylon Fusion paint, though I don't know how well it stands up to stretching. Vinyl Dye paint like Plasticote's Ultra Vinyl Color are also worth a try. Here's a tutorial you might find helpful.
http://linear1.org/mods/vdye.php
If you ever find a source for the really thin stuff, be sure to let us know.
Gas up your creativity at www.IDFuel.com
Postby amanda » October 26th, 2004, 11:42 am
amanda
Hey- Thanks for the reply. I found some transparent and opaque vinyl, so that should work out. I also might be getting some scraps from a vinyl manufacturer :D Thanks for your help!
Re: Material for inflatable toy system
Postby ralphzoontjens » August 17th, 2017, 6:46 am
ralphzoontjens
Hi
Thanks for sharing. I am looking to develop a small series of inflatable products too and am interested in any literature or experience people have on the topic of how to get from 2D to 3D complex shapes. Tubular shapes are quite straightforward, but what if we want to develop, say, a large inflatable horse?
Thanks,
Ralph
http://www.designsoul.nl
Postby Dan Lewis » August 17th, 2017, 8:27 am
Dan Lewis
ralphzoontjens wrote:Hi
Thanks,
Ralph
I looked for similar processes a while ago -- I found two, both Rhino 5 plugins:
LAMINA http://laminadesign.com/ Reasonable cost
ExactFlat http://www.exactflat.com/ Expensive
Postby iab » August 17th, 2017, 9:02 am
iab
Hi Ralph,
Air inflation will always follow the second law of thermodynamics, entropy can only increase over time in a closed system. That is the physics behind making 2D shapes into 3D shapes with air inflation. Pretty worthless practically.
But for your horse, let's talk about what you can do. Obviously, you can make a leg with a bend 2D and have the top wider than the ankle to be more realistic. The trick will be in attaching the "cylinder" leg to the "cylinder" torso. I hope this makes sense, but in some case you could be welding with 3 pieces of material in the equipment when you only want to weld 2 pieces of material. It is an easy trick to use a thin piece of teflon sheet between the 2 pieces of material you don't want to bond. But you need to make sure you don't "trap" the teflon in the finished good. Your manufacturing steps need planning.
Ways to make shapes not always "cylinders" pretty much comes down to 2 methods. Spot welding between the seams. This will create a tufting effect. The other is to use flat gussets between your two primary sheets. For example, imagine how they wrap aluminum (your primary sheet(s)) around the the multiple frame elements (gussets) that make the wing profile. The only downside is you will see the weld marks of the gussets on your primary sheets.
Like I mentioned in the other thread, get a roller sealer, teflon film and PE film from McMaster and experiment. It's fun.
Postby kdino1 » August 17th, 2017, 9:34 am
kdino1
Depending on material size needs, it may be beneficial to buy a few low cost pool floats and cannibalize them for your tests/prototypes. at the end of the summer, places like walmart and target are selling their floats at a heavy discount, almost $1.00
Postby moczys » August 17th, 2017, 10:59 am
moczys
step one
step one
Helium balloons at the supermarket would also be a good source of inspiration/research to look at how the seams are designed to create different forms.
Just make sure you think through where the inlet is placed! I saw this in a store a while back and it made me do a double take. I feel like this was a serious oversight... :shock:
yikes!
Postby KenoLeon » August 17th, 2017, 11:13 am
KenoLeon
Marvelous Designer has this feature where you can inflate (pressurize) your patterns after you've sewn them, just be careful with the stitching (I think inflatables are heat welded but same concept ) since some of it does not translate 1 to 1 to real life, but will give you a head start on the final design.
Eugenio (Keno) Leon
k3no.com Linkedin Instagram
Postby ralphzoontjens » August 24th, 2017, 8:16 am
ralphzoontjens
that is a great tip. I appreciate also your short review of Marvelous you did.
Postby ralphzoontjens » August 24th, 2017, 8:19 am
ralphzoontjens
There is also Ivy for Grasshopper, free for commercial use. It is more geared towards papercraft, but still nice.
